Hello All. This is my first post. Hopefully this place doesn't hate noobs. :awe: I don't think it does.
I'm purchasing new computers for my office for several users. I want to go with systems that can easily support Windows 7 64 bit for the future. I have a pretty big investment in Nortel Unified Messaging systems though. At this stage, Windows XP is a pretty big requirement, still.
I use all Dell systems, and they're pretty amazing about all using other Dell install disks. For example, if I have a system that came with an XP SP1 disk, and need to reinstall windows, I can stick an XP SP3 install disk in it from another Dell and it works. Pretty nice! I assume HP and other major manufacturers are the same way.
My question to you is whether or not this will be an issue going between Windows 7 Pro 64 Bit and Windows XP 32 bit. I'm looking at Optiplex 980 systems.
Or, am I looking at this entirely wrong? Should I be running a Virtual XP from these machines?
Thanks for your help and input.
