LianLi PC70 issue
nicowju
3,880
I just saw some pictures and read a couple of reviews, and it looks like there isn't a hole at the bottom of the PSU mounting area for those Enermax PS's. This means they have to be mounted upsidedown :( Anyone know of a site that sells these modded?
Swanny
7,456
I thought the same thing, but the mounting system for the PSU (at least on the PC60) is a bracket screws in just to the back of the PSU and the bracket in turn screws into the back of the case. The bracket does not cover the entire unit, only the back. All I had to do to get my Enermax in was take off the bottom fan grill so it could slide through the case opening and then screw the grill back on once the thing was inside, which was a little bit of a pain, but well worth it:D
fitzhue
1,242
Swanny, do you have any pics of that? I've heard people do that but i don't quite understand.
nicowju
3,880
Yeah I want to see that too if you could :) I've got this 550W Enermax PS sitting here and I want to use it! :)
Tweakmeister
646
The plate that goes over the psu (on the back of the case) can be reversed. (I mean the plate that the back of the psu screws into). I'm looking at mine and although the psu would have to be mounted upside-down, it should work just fine.
nicowju
3,880
Aww okay. Looks like I may have to do that with my Enermax then :(. Either that or try to drill through all that metal :)
