Lian PC-70 case does NOT have a Slide-Out Motherboard tray!!!!
VBboy
Does this Lian silver PC-70 full-tower case have a slide-out motherboard tray?
I can't find any reviews that talk about this feature.
I know the PC-60 (Mid-tower) has it..
Post any info available! Thanks.
*** I found out it does NOT have the slide-put tray !!!
<a target=new href="http://www.dansdata.com/pc70.htm">&quot;Oddly, the PC-70 doesn't have a slide-out tray, and so doesn't have the two-part connector lead loom, despite being a big case. Big cases are the ones most likely to have this convenience feature.&quot;
</a>
all the cases from lian li have removeable trays. The thing about the lian li case is that it suppose to be &quot;TOOLLESS&quot; install. You can pretty take off any part of the case like the pc-60.
You know I was looking at picture of that case and I don't think the mobo tray comes out. But there is so much room in that case why would you want to take it out?
Sweet case. I like my pc60 but with my new scsi, I would love to get my paws on that. 🙂
Matt
lilnnjaboy,
I know, I was probably looking at the same picture, and compared to the Mid-tower version this one doesn't seem to have that slide-out tray! That sucks buttocks.
I need that tray so that I don't have to dig deep inside the case to flip a switch on the mobo or to install RAM, etc.
The only BAD thing about those cases is that the PSU enclosure is closed at the bottom so if you have a PSU with a secondary intake fan at the bottom (like Enermax) you will not benefit from it at all. You can always cut out a hole of course 🙂
Got my PC-70 this week.
There is no slideout tray. It's not really a big deal because the case is sooo big.
I have an Enermax 550W Power Supply (overkill.... I know) By flipping the face plate around, the PS can be put in upside down without cutting any holes.
This case ROCKS!! I'm very happy with it!
