serializable
- Aug 24, 2006
- 29
- 0
- 0
Heres some pictures of the v1000 plus II that I took.
Looking through side panel
Side panel off
Here you can see there is plenty of room for a longer video card. The heatsink just barely fits despite its large diameter.
Close up of top compartment
This is the 120mm front fan I added to the top compartment. Its held in place with zip ties.
Front fan added
From the previous pictures the bottom looks a little cramped because of the spare wires from the powersupply. This picture does a better job of showing how much room is down there. The powersupply has a fan on the bottom that isn't blocked. Also there is plenty of room under the one harddrive to put the unused cables. The only reason its there and not in the first bay with the other 2 is that the ide cable is only 10" long.
Opposite side lower compartment
So theres the pictures of the case. Here are some temperatures while at idle. Room temperature is 74F. Everything is running stock.
Temperatures
Side panel off
Front fan added
Temperatures
