TangoJuliet
Here is my Lian-Li build....all the components are in the sig.
There were some minor changes I'll explain as I go along....tell me what you think.
Here is the case with nothing in it. It is a v1000b Plus II with side window.
http://s2.supload.com/free/1-20060710201807.jpg/view/
http://s2.supload.com/free/2-20060710201814.jpg/view/
I had several holes cut into the case to route the wires more efficiently....(3) on the top for the USB, IEEE, and SATA cables. There is a cut right in the middle so I could route the cables under the board and behind the case. Two more holes on the bottom right for fan wires, etc and one more hole on the bottom right that was going to be for the PSU but ran into some trouble with that. I am going to upgrade my PSU in the future so that hole will come into play later on....for now I had to make due with what I had.
http://s2.supload.com/free/5-20060710201956.jpg/view/
http://s2.supload.com/free/8-20060710202005.jpg/view/
I had everything in temporarily when I ran into a problem where the 18" SATA cables would not totally reach the HDDs. The one drive was ok but the 2nd drive was really stretched. I quickly ordered (2) 24" SATA cables (installed them today).
http://s2.supload.com/free/IMG_1342.jpg/view/
http://s2.supload.com/free/IMG_1346.jpg/view/
Here are 2 temporary pictures of it all setup before I ran tests to make sure everything was hooked up correctly.
http://s2.supload.com/free/IMG_1347.jpg/view/
http://s2.supload.com/free/IMG_1350.jpg/view/
Here is the reverse side of the case where all the wires are being hid. As you can probably see the SATA cables are being stretched to their limits to reach the bottom HDDs.
http://s2.supload.com/free/IMG_1358.jpg/view/
http://s2.supload.com/free/IMG_1359-20060710203332.jpg/view/
Finally today I got the 24" SATA cables, took out the old ones and re-routed the new ones. I also cleaned them up a bit to be more streamlined.
http://s2.supload.com/free/IMG_1372.jpg/view/
http://s2.supload.com/free/IMG_1373-20060710203606.jpg/view/
Here is a shot of the holes on the bottom right hand side of the case where I was able to route the 4 pin PSU cable as well as the audio cables and PSU fan.
http://s2.supload.com/free/IMG_1374-20060710203826.jpg/view/
Here is a cleaned up shot of the interior without the 120mm fan, blower and video card in the way.
http://s2.supload.com/free/IMG_1375.jpg/view/
Now with the video card installed
http://s2.supload.com/free/IMG_1377-20060710204155.jpg/view/
And with all the case parts installed. As you can see that PSU cable is an eye sore but with the side panel on it is not noticeable and plus its only temporary.
http://s2.supload.com/free/IMG_1380-20060710204202.jpg/view/
Finally with the panels on and a frontal view
http://s2.supload.com/free/IMG_1381-20060710204333.jpg/view/
http://s2.supload.com/free/IMG_1385.jpg/view/
So what do you guys think?? Also, for all you Lian-Li owners what is the best way to clean up all of those fingerprints? 😉
