I was wondering if the XP-120 would fit in the new Lian Li cases also. This article at overclockers.com has a couple pictures that show the XP-120 hanging over the edge of the motherboard quite a bit.
Here is a Pic of the case with a motherboard installed. Doesnt look like it will fit without a little modding. Hopefully someone will get the XP-120 and try and install it in one of these cases soon 🙂 .
