Lian-Li Support?i
SparkyJJO
13,357
7
Originally posted by: Mr Bob
I can't call that from the US.
Sure you can, but for a price. But if they don't have any other phone number than that you're stuck with it or the website which you said apparently isn't working right. Might give it another try to see what happens.
I still think it would be easier to just buy a new fan, only a few bucks for one and much less hassle it would seem at this point.
Mr Bob
1,757
12
"Why not?"
- Because it is restricted... only local and the UK here...
"I still think it would be easier to just buy a new fan"
- It is MUCH easier to just buy a new fan. That wasn't the point of this thread, it was to find the lian li support information. Do a search for Lian Li support in google, this is the 2nd link that pops up. Apparently not many people have talked about lian li and support.
I'll have to contact newegg and hope that they have their support information.
AmphibSailor
1,399
"Why not?"
Really sounds like a self imposed restriction. Try another telephone...unless you're not paying the bill. Then use an international phone card, for goodness sake.
Boyo
1,406
Originally posted by: SparkyJJO
IMO fans included with most cases - regardless of who made the case - are cheap things anyway. Easier and probably cheaper to replace it than pay to ship back a fan for RMA.
Exactly. Now just try and convice the OP of that.
Kaadg
55
I had the exact same problem with my Lian Li fans; I also got no support from Lian Li.
They way I solved the problem is that I plugged the fans straight to the 5v power supply instead of the motherboard. the MB supply was about 1.6v, so perhaps that was too low for the fans. The fans run faster, but I'm OK with that. My fans came with an adapter to fit the Molex connectors.
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
I had an issue somewhat like this... I was putting some equipment into the case, and when I was done, I couldn't find one of the little plastic pieces that allows the front panel to be installed. I did the Lian Li service thing, but their entire system has messed up errors--I either get an error upon posted the message, or I get a blank e-mail after.
Luckily, I posted about it on here, and Zepper posted a link of where the part could be ordered... So it should be in the mail or something to that effect as of now.
I bought the case from Performance PCs, and they have been exceptionally helpful thus far, as they are trying to locate the part for me as well.
In regards to cases, I don't think I will be getting or recommending Lian Li again... Enermax & CoolerMaster are still on my good list though.
EDIT: Here's the website that has Lian Li case stuff. You might want to see if they have your exact fan and everything, if you want an exact replacement...
hotsoda
551
I'd like to know how I could get a hold of Lian-Li as well. I remember getting a reply from them a long time ago, but from what I've seen, their support in non-existent.
herbiehancock
789
Me neither... :D
Funny, my decision was through experience... And your's was via, what? Just remember, I'm pointing this out for your own good. ;)
Damn, that was good!!! But most likely it'll just pass straight through the vacuum that his head encloses without making a sound or impression.
