Lian-Li PCV1000
DMonkey
49
Does anyone have this case and the Antec Neopower? I am wondering if the case will fit it since the PSU portion of the case seems a little small. I can't muster up the measurements of the Antec Neopower because I don't own it yet, but if you have both the Neopower and the V1000 please give me a reply!
akira34
1,531
I have the Antec NeoPower inside the V1100, if that helps any... It's a bit of a snug/tight fit, but I got it in there.
DMonkey
49
Thanks, I guess the Neopower will fit in the V1000 anyway as the V1100 seems to be the same case with some cosmetic differences.
