lian-li pc68 and USB port Question
JimmyG
24
got most of my new sys and i was just curoious as to how i go about hooking up the USB ports on the front of the lian-li pc68 case to the motherboard. I have an asus a7m266 board.
The front of the case has 4 ports, 2 cables feeding to two ports. (1 cable has port 1 and 2 on it, other is 3 and 4). I do not see a connection on the mother board for the ports....is there a certain card i have to buy?
thnx
Jex
588
Looking at the Asus web site, the page says your mobo had one additonal header to support 2 USB ports. I think one of the cables for your case can plug into that.
Link to your mobo specs
I couldn't get the manual to come up, so I don't know exactly where on the board the header is, but if you have the manual, you should be able to find it.
JimmyG
24
ah, so i will only be able to use 2 of the 4 front usb ports ? not that it matters all that much, but the USB header is for the additional 2 usbs other than the 2 on the back of the board.
thnx for the reply btw.
jim
