Lian-Li PC60/68 Question?
Bingo13
1,269
I am currently using the PC60 case and was wondering if anyone has the PC68 model. If so, any major differences or improvements? Is anyone having issues in removing and reinstalling components several times. I have noticed some "flex" developing in my PC60 case after doing several change outs that has not occurred in other cases I own.
thanks....
MCS
2,519
What do you mean by "flex" exactly?
The only difference between the PC60 and the PC68 is that they have changed the colour slightly and the front bezel, and added 4 USB ports on the front. Personally I can't stand USB ports on the front of cases, and I think the PC60 looks a look better!
Bingo13
1,269
The cases do not seem to have the same rigidity that they once had or seemed to have. I am getting some warping on the back panel at this time on one case and a bow in the motherboard area on another. I love the case, just wondering about the long term effects of moving components in and out of the case.
MCS
2,519
Oh dear!
So are you moving componants in and out of the case A LOT?
I did notice that I could probably bend the side panels in half using one hand though :)
Bingo13
1,269
I move components on a almost weekly basis now, it is the only concern I have about the case right now. It probably would be fine otherwise but I am abnormal when it comes to switching components in and out.
MCS
2,519
Jesus I just looked at your Rig page and I see what you mean now!
You've got the upgrade bug REAL bad :)
