- Sep 28, 2011
- 7
- 0
- 0
It's time for a system upgrade, and I love Lian Li's new PC TU200 . I have a work laptop already for travel, want to add a portable gaming rig I can drag into the bedroom and hook up to the 46" TV, or over to the in-laws' during the holidays. This case will meet my needs, and I'll throw down my $$ to the first vendor to have it in stock. Would appreciate some feedback on choosing my first mini-ITX motherboard and cooler.
I've got a new i5 2500-K on the way (thanks NCIX price matching!) I have a spare Antec Kuhler 620, but I doubt it will fit in this case, so #1 son will likely find it under the Christmas tree. Recommendations for a low profile cooler to replace the stock?
I have some Kingston HyperX 8GB DDR3-1600 leftover from a build earlier this year (went with a 16GB kit instead), that would be nice to use.
I've got a Crucial M4 SSD 6GB/s that I've been saving for a special occasion. I'll probably skip RAID, but add a second 1TB.
Only need 1 gigabit LAN port. Due to limited ports on a mini-ITX motherboard I'd like to find integrated wireless N and bluetooth. I'll use my Razer Orochi (highly recommended if you have small hands!) via BT when moving the system around, wired up at when at the desk. Prefer BT A2DP so I can also use my Sony headset and keep the spouse happy re: noise levels.
I'll probably re-use my Geforce GTX 460 for now.
The Asus P8H67-I would be perfect, except it's SoDIMM. The ASRock Z68M-ITX/HT can handle my spare RAM, but doesn't have wireless or bluetooth, and I'm concerned about stable overclocking. Suggestions? (No Zotac please, I only want to build this thing once.)
