Purchased a GA-P35-DQ6 mobo with the F-Audio plug at the back middle of the board behind the Northbridge. I have a Lian Li PC-60APLUSII. The cable from the front panel for MIC & EAR will not reach the F-Audio plug. Is there an extension cable I can get and if so where? What type of cable is this and what's it called. Right now the closest I can get is to run the cable behind the HDs and then across the video card, but doesn't quite make it.
This would before AC'97 Front Panel Audio. When I google I see references to it, but can't find a place to buy it. A search on Newegg didn't turn anything up, but maybe I am not using the correct keywords.
I tried to email Lian Li, but waste of time and just got an error message about the database on submit.
