Lian-Li Mousepad question
RacerX
I just got a silver M-2 Lian-Li mousepad to match my case but it hates my mouse. What I am wondering is if it's the surface itself or the color?
I have a Logitech optical cordless mouse and it works fine on my black Everglide. I was going to get a black (they have two versions) one now but if it's the aluminum or surface I really don't know if there would be much difference and still might get the same results with a black one. These pads are really cool but it jitters to much with my optical mouse.
If anyone has an old style ball mouse and a Lian-Li case this would rock and it's nice looking and would match ... drop me a line I will sell it for free just maybe shipping cost? ... I just didn't know whether the black color would make a difference or if it was the aluminum surface that's the problem. thanks for any advice 🙂
You probably should have posted here before you bought that mousepad, I bought that pad and neither my optical or regular mouse wanted to work with it. So I now use it as a base for my portable drive 🙁
I bought a Everglide Giganta instead and its worked fine for me so far, but since you use an optical as your primary mouse, you might wanna get something else!
Just a suggestion.
