Lian Li LANCOOL 205 Mid-Tower Chassis ATX Computer Case PC Gaming Case - $55.99 at Amazon w/Prime
Steltek
Link
Hard to find anything to match the quality of this case at $55.99, available in both black and white at this price.
  • Computer case with clean aesthetic. Dimensions: 8.1 x 16.3 x 19.1inch. 0.8mm SPCC front panel and SPCC 0.6mm main structure with plenty of room for all components, make it durable and roomy for your first build, 1st PC, theater and gaming PC
  • Gaming PC Case with tempered glass side panel allows for a great view of your RGB components. Changing motherboard size supporting ATX, mATX and Mini-ITX
  • Mid-Tower Chassis with ease installation design. Removable SSD mounting brackets, swappable top and front fan brackets and bottom side panel PSU and HDD bay. Change with no more pain
  • Desktop computer shell case with professional cable management solution. Extra space behind the motherboard tray for hidden cable organization. I/O essentials, 2xUSB 3.0, Power button, audio out and in on the top
  • High air performance with Magnetic Dust Filter, Side Ventilation and 2 Pre-installed 120mm fans. Magnetic dust filters on top and front, dust filter tray at bottom. Liquid cooling ready
@SamirD, still loads to cart at $55.99 for me.
Are you logged in and do you have Prime? If so, there is a 20% off Prime Day special that drops the price down to $55.99. Make sure the seller you are looking at is Micro Center.
