lian li k7b owners?
bigKr33
I'm gonna be building a computer sometime around march-april time frame next year. Right now my computer plans is nothing more than brain storming for the right case. I want it compact and rigid. The k7b looks like a good option for water cooling because of the amount of space in the front. I would like to bolt a dual rad in the front. Does anyone know the dimentions from the inside front bottom of the case up to the bottom of the 3.5" bay? Just curious because i'm thinking i may have to cut the 3.5" bay out to fit a rad. Best requards
Yeah thats the case. I was planning on removing the hdd cage if i were to get the case. I accidently left that part out.
Okay, I get what you mean now. It is 9.5", just barely enough for the two 120mm fans. You'll have to cut out the FDD bay and mount the radiator upside down, and hope it fits. If it does then you'll have an awesome water setup in such a small case.
