Question Lian Li Galahad 360 - very loud
AzowiX
I have this AIO and that is very loud right now due maybe to one of the fans that has defected and always do some tickling sounds..
But anyway this AIO is very loud especially on heavy tasks..
Thats possible to disconnect one of the fans of the AIO right now to stop the defective fan or that is risky?
Ryzen 9 5900X CPU.
RickyBubby
I would first diagnose the issue by unplugging each component until the problematic noise is gone.
Then, I would contact the manufacturer immediately after trying to reasonably resolve the issue yourself.
You should read the owners manual, service manual, warranty manual to verify if there are corrections for the issue. You may be able to check the end play of the fan blades for a defective bearing or fan blade casting. The fan may require grease, the fan may be non-serviceable. If defective, the product is *usually* covered by a limited manufacturer warranty. I would contact the manufacturer immediately after trying to reasonably resolve the issue yourself. Cheers
