P pcslookout Lifer Mar 18, 2007 11,959 157 106 May 17, 2017 #1 Do Lian Li cases come with the screws to mount fans in the case ? My case doesn't come with fans.
C Crono Lifer Aug 8, 2001 23,720 1,502 136 May 17, 2017 #2 I don't know, but since most cases use the same type of screws for mounting fans, it's worth it to have a pack on hand: https://www.newegg.com/Product/Product.aspx?Item=9SIA98C3RC0303 There are some longer type screws, too, but usually they come with cases that need them.
P pcslookout Lifer Mar 18, 2007 11,959 157 106 May 17, 2017 #3 Crono said: I don't know, but since most cases use the same type of screws for mounting fans, it's worth it to have a pack on hand: https://www.newegg.com/Product/Product.aspx?Item=9SIA98C3RC0303 There are some longer type screws, too, but usually they come with cases that need them. Click to expand... Thanks I just got this email back from Lian Li support! Hi The case include fan screws . Click to expand...
