Dante Rising
I'm relatively new to building computers, and decided on the Lian Lim PC-X900. Everyone rates the Lian Li PC-900X very highly, but one review had this to say:
I ran into a number of issues when building this machine, the biggest one was an electrical short caused by the stock screws and power supply mount. This was remedied by removing the removable power supply bracket that came with the case, this bracket was used to make the power supply mounting tool less.
The other culprit of the electrical short circuiting was the thumb screws that came included with the case to mount the motherboard to the standoffs. When you mount the motherboard with the thumbscrews it causes random losses of power which will cause system restarts every few minutes without any major blue screen errors leaving you scratching your head. The fix for this was to replace the stock screws with standard computer mounting screws.
http://www.techwarelabs.com/lian-li-pc-x900-casechassis/2/
No one else mentioned this issue in their reviews, and I was hoping someone else could explain what he means. What, exactly is the reason for these shorts? Is this a true cause for concern, or did this reviewer just not know what he was doing? Was it the type of power supply? Improper grounding? How could thumb screws cause a short? I've only built two computers, so I'm not very adept at this. I would appreciate someone taking the time to clarify this for me.
Is this reason enough to avoid this chassis?
Thanks!
Thanks!
