LIan Li BS-01 Blower Fan Useful?
reddevil0728
119
http://www.lian-li.com/images/products/b_blower_bs-01.gif
http://www.lian-li.com/Product/Accessories/Other_Blower_fan.htm
Will this Lian-Li accessories help in drawing out excess hot air from those expansion card in my casing? I only got a graphics card there, so would like to know if it is worth it to burn the fan so it can directly draw out the hot air of the graphics card when the heat is removed by its own HSF?
http://i51.photobucket.com/albums/f374/reddevil0728/IMG_0277-1.jpg
The red circle is where the blower would be placed. VF900CU is installed.
yh125d
6,907
I imagine it should make a difference, however small. If you are using a passive-cooled card, it probably would lower temps more than an actively cooled card.
reddevil0728
119
I am using a 7900gt with vf900cu... no other expansion card... so will it help?
SexyK
1,343
4
Originally posted by: reddevil0728
Originally posted by: LOUISSSSS
short answer: yea, it will
Whats the performance gain? reduce temp by 3-5 degrees? or just 1-2 degrees?
Impossible to say for sure, but I'd guess closer to 5 than 1.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Squirrel cage fan - nice! :)
There's no telling how many degrees it will reduce the temperature. (Not without expensive thermal scanners and lots of calculus hehe.)
IF the air down in that area feels warm chances are it will cool the lower part of the box off a few degrees at minimum.
Boyo
1,406
I think the Zalman will provide better cooling than the Lian Li blower.
