dealseaker
i use 1.65 volt, slk800 hs, 2900 cfm fan, stock speed on 2500 cpu, i never really ran the pc with the side on it, then i decided to put some deadening material on both sides, top and bottom, also added another fan on the back, i have two 80mm intake fans, and two 80mm exhaust fans now, is that temp too hot my cpu?
