Originally posted by: VinDSL
Originally posted by: JB77
Hi
I am a relative newbie builder and...
Welcome to AnandTech!
If I was you, I'd take a step back and reconsider your choice of cases...
I've seen this a zillion times - n00b buys Lian-Li, thinking they discovered something great, only to find out everything is upside down and backwards.
Do a little more reading, my friend!
I agree with Vin regarding reconsidering your choice of cases. Many manufacturers offer great cases for significantly less than what it costs to purchase a LL and it is a little disorienting working on a reverse ATX case, but you'll quickly get over it. The learning curve on using an reverse ATX Lian Li case isn't that steep.
With that said--if you're DEAD SET on purchasing a Lian Li--I currently own an A05 and V1200. I'm very happy with both. With respects to my V1200, it provides the depth of a full tower case without the added height. Ample cooling and, of course, plenty of room. I considered the V1000 (and V1100 for it's silencing properties), but in the end I went with the V1200. Here's why:
1. I don't want to open a case door everytime I want to turn on my computer. I don't access my optical drives often. If I do have to access the optical drives or my media reader a lot, i.e. burning CDs or DVDs or pulling photos off of my SM card, I may consider taking the door off, which would defeat the purpose of me buying a case with a door. It's an easy process, simply push the blue tab and off it comes, but why convert your car to a convertible when you could've bought a 'vert to begin with. Sound deadening material can always be added to the case and overall noise depends on the components you use anyway (i.e. fans, hard drives, etc).
2. The V1000 and V1100 have plenty of room but I simply wanted more. The price difference between the V1000 and the V1200 wasn't that much more. It gives me the option to install an E-ATX motherboard in the future and I don't have to worry about making sure long video cards fit.
Go for the V1200 if you use a long power supply (you'll have to modify the V1000 to fit long PSUs) and if you want more 'elbow room'.
