Lian 60 plus vs 60 plus ii (how do they differ?)
you2
Does anyone know off hand the differences between lian 60 plus and lian 60 plus 2?
Thanks,
You
The Plus model has a special blower-style fan that sits in front of the expansion cards and blows air out the back. The Plus 2 model replaces that with a normal 120mm fan, which blows out a set of perforations in the side panel.
Is there a big difference between the two ? Almost sounds like the plus version would cool better ?
Most of the time when manufacturers try to add special new features to a series of cases, with new blowholes, expansion bays, redirectioning tunnels, etc. it doesn't turn out how you would expect.
The PC-60+ is a good case. I added some Yate Loon fans to mine and they're very quiet. Helped circulation greatly.
Which fans did you replace with yate?
(I had intended to order plus 2 but misread a description and ended up with plus - it seems like a nice case so far - only
complaints - I think i would prefer plus 2 fan location and it was a pain to install the optical drive. Finish quaility is very high and price was reasonable ($110).
