Well there is the 3980X that is as of yet announced. It comes out about 2 weeks after the 3 announced versions. Likely the 8 core extreme edition.
Not 8 core but 6 core, according to these guys.
Fair enough, I guess I should have imbued my post with a little more specificity.Crappy memory traces, poor voltage regulation, etc, will all still deep-six an overclock effort even when the overclock is being done via multiplier steps.
I had one of those original unlocked multi extreme quads (whatever it was back in Nov 2006, the Q6700X or somesuch?) and the max OC I could get was entirely dependent on the quality of the motherboard I put it in.
Your question is really no different than asking what good is it in having different PSU manufacturers, different DDR3 dimm producers, or different AIB's producing the same class of GPU products...differentiating factors will still be present as each company makes different decisions in terms of cost-savings and feature points.
Oh, we'll find something to use it eventually. I've said that to myself countless times before :What will people do with so much processing powers on their PCs? Its like everybody driving a Veyron few years down the line.
AMDs 32 on llano doesn't look so good . Not good at all. power hungry and slow.
What I meant was for motherboards within a given minimum price/quality tier, there seems to be less differentiating them now. I have always had good luck in achieving good overclocks using more economical boards (965P-DS3, EX58-UD3R, IB9, AB9 Pro, etc.)
As long as the board works for a given stock memory rating, it should work. I guess the most integral remaining factor is voltage regulation (apart from layout and maybe color scheme).
It will still come down to the quality of the motherboard design and the components used on it, right?
Which one was that? I got one of the cheapest X58 boards for my i7 setups (EX58-UD3R Rev 1.0 and Rev 1.6). They've been working fine 24/7 and keep my 920 D0 @ 4GHz on air.After my x58 mobo fiasco (3 mobos now) I've promised myself to get a quality mobo next time around. I got spoiled with the ip35 pro from a price/performance perspective, I don't see any others like that coming around again.
3930K will run for $500-$600?
Ugh. What happened to the days of the godly i7 920/930? $199 at Micro Center? OC to 4ghz easily... sigh.
Sure the budget SB-E will still be $300, but you can't OC it at all. I'm sure a 2600K overclocked would squash it.
On a more positive note, there would be a natural limit to what they can charge (not saying it will be well within our comfort margins, just saying there will be a limit), so it won't exactly increase with every release. Intel is competing with themselves, and with each generation they have to convince a significant portion of their entire market that it is worth it to upgrade - either for the extra performance, lower power consumption, cooler temps, or any or all of them combined.Unless the threat of amd or arm actually materializes, expect the price points to creep slowly, but solidly upwards with every release.
Or compatibility
I'm sure intel(or any other company) can come up with a way to engineer some planned obsolescence in there to stay employed.
I'm guessing that the problem was too many people went for the 920 instead of the middle tier. Management has an easy solution for those kinds of pesky cheapo customers!![]()
Will never go back to 130W CPUs ever again.
<==== Happy owner of 2500K
