I'm putting together my first LGA 775 based system and got a Asus P5VD1-X and boxed Intel processor. Intel's instructions say to install the m/b in the case before installing heatsink, and then just push clips until they pop. It became very clear that the amount of force required to seat the clips would be way too much flex on the motherboard in that scenario so I took the m/b out and looked at it. If I fully seat all 4 clips, the m/b is visibly pushed out - convex - on the underside below the processor. This doesn't seem right nor healthy for the life of the m/b.
So the question is, is this normal? Or is there a problem with this m/b? Or the heatsink?
I have the processor correctly installed, I've booted from it and the BIOS is happy with things. It ran the Windows memory diagnostic overnight without errors. So the issue isn't processor installation.
