- Nov 23, 2010
- 14
- 0
- 66
Hello all!
So I've decided to update my rig. I've been looking at mobo's on different sites and reviews on those same sites. I've come down to the fact I don't need a super built out mobo.
I've done some research and based on my needs. I think the following are good choices.
I just wanted some advice on what you all think.
Needs:
List I've been looking at:
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007627%2050001314%20600315497%20600176034%20600008960&IsNodeId=1&bop=And&CompareItemList=280|13-138-356^13-138-356-TS%2C13-157-304^13-157-304-TS%2C13-157-293^13-157-293-TS%2C13-128-543^13-128-543-TS
I'm not a fan of the Gigabyte's board and its off kilter LAN and Audio solutions, more the LAN as it is Atheros GbE LAN chip, VIA makes good audio I think.
I will OC a bit, getting to 4.6ghz would be nice, but I don't plan on pushing it to the hilt. Seems the CPU will be plenty fast coming from a q9550 & ati5850.
Thoughts?
Thanks in advance!!!
Needs:
- Less than $150 for mobo
- 1 GPU, I will never do SLI or Crossfire
- I will be buying either the i7-3770K or the i5-3570K
- GPU will be the 670, not sure which yet, looking for a good cooling one (probably either MSI, Gigabyte Wind or Asus DCII)
Thoughts?
