LG L246WP: SOLVED! - 1:1 screen resolution using DVI/HDMI & Component input
jmorton
15
L246WP had user controlled 1:1 pixel resolution all along.
This WAS apparently an unresolved forum issue that I have just resolved. (I simply thought I should first consult the user manual. It is a PDF document so I searched for "1:1" and the exact page I needed appeared.)
When you connect the L246WP to an external source such as a set top box that receives over the air digital broadcast televison like I have, you can set the monitor to display in either full screen or 1:1 pixel mode. This function is only available when either DVI/HDMI or component input is used.
Here is how it is done.
Using either the DVI to HDMI cable and connecting to the set top box DVI output to the L246WP HDMI input or using the set top box component output to the L246WP component input, you first bring up the Input OSD and select either HDMI or component input. Next you bring up the OSD menu and select SCREEN. Then you select ARC. Here you will see two possible options: FULL or Original (1:1). If you want 1:1 pixel resolution check Original. If you want to use all of your screen real estate check full. (here you'll get some vertical stretching but the picture is, well... full.)
That's all there is to it.
I prefer DVI out from my set top box to HDMI input to the L246WP because I believe that the contrast is better and the colors more saturated than with component. But I have found that you need a strong clear digital broadcast signal to get an optimum picture without any edge artifacting. If I do get some distracting edge artifacting using the DVI to HDMI input I just switch to component and the problem goes away.
The LG L246WP is the greatest!
(Apparently as this was a problem with the Benq 24" model it hasn't been, at least since I got my L246WP, with the LG. That is if you take the time to read the user's manual.)
JM
(AS)
BernardP
1,315
Good info, thanks.
This is for TV applications. What about 1:1 pixel mapping from a computer source, in games for example. Does it work the same way?
jmorton
15
Originally posted by: BernardP
Good info, thanks.
I am not a gamer although I plan to get a popular title soon when I upgrade my video card. I'm considering the ATI HD 2600 XT (possibly in CrossFire) when it comes out or maybe the 8800 GTS.
I have only watched standard DVDs and a high definition theatrical trailer of "Van Helsing" which happens to be in .avi format using Windows Media Player. Standard DVDs look splendid, especially in full screen, while always retaining their aspect ratios.
And the 720 HD Van Helsing trailer is like WOW in perfect aspect screen resolution. I recommend using the Media Player's audio enhancement SRS WOW effect. You can download the trailer at: http://www.drfoster.f2s.com/trailers_hd-dvd.shtml
JM
(AS)
xtknight
12,974
I think his question was: can you set your resolution setup to monitor scaling and set the resolution to 1280x1024, for instance? Does it let you do 1:1 from a PC source?
Thanks for the info, good to hear this has been resolved (for other video sources, at least).
