News LG 27" 1440p 240Hz OLED monitor!
Heartbreaker
5,028
6,596
Finally flat desktop monitor OLED. Stealth launch spotted by Vincent at HDTV test.
LG product Page:
$999
27GR95QE-B
27'' UltraGear™ OLED Gaming Monitor QHD with 240Hz Refresh Rate .03ms Response Time
Reactions: Leeea
aigomorla
21,044
3,524
I was looking at this and the 32 inch.
Decided to go 48 inch as its half the price of the 32.
I do not have the 240hz refresh rate, but i do have 138hz, which isn't too bad on a 4k monitor.
Although i think the monitor is a big too big and overkill for a desk, but it seems to be working fine.
I do not like the auto contrast they have built in.
I am also not too sure about the burn in protection.
It has a funky screen saver option which shifts your window ever so slightly so no pixel is stuck in the same location too long.
It will make your window sometimes out of sync on the border, but you can quickly fix it.
But i can see the little tweaks LG has done on the OLED monitors to protect you from burn in over the C B and G series HDTV's.
Only time will tell if it actually works tho.
