LG 226WTY-BF users...does it buzz when on?
asintu
628
Does your monitor have a noticeable buzz when it's on? Is it normal My old Samsung is completely silent so I find the LG distracting.
Blazer7
1,136
12
My old LG was completely silent and my new Samsung is too. In fact I do not know of any monitor that will buzz when on and be considered normal. I would say that something's fishy. Have you checked your cables? Are you running @native res @std refresh?
asintu
628
yes 1680x1050 and 60Hz. Thing i noticed is when i increase the brightness the noise goes lower and lower!!!
s44
9,427
16
A lot of poorly constructed monitors have this problem. It's some sort of issue on the power side. RMA.
Blazer7
1,136
12
Well that's a first, I've never heard that before. This sounds like bad circuitry or power issue or both. One way or the other I think that I'll agree with s44, RMA.
asintu
628
can anyone that actually has this monitor try this test (decrease brightness) to see if the buzz comes on? btw put your ear to the side of the monitor.
asintu
628
i'll exchange it tomorrow i guess.
asintu
628
little update...just got a new one and has the same "feature". can someone that has the monitor test this please?
