Lexmark E 210 printer..HELP quickly! what cable do I need?
murphy55d
11,542
I am going to order one of these...it says cables not included. I am getting it from Staples.com, could anyone point out what extra cable I'd need to buy?
Thank you! :)
ScrapSilicon
13,625
<< The standard built in bi-directional parallel and USB ports give this printer expanded connectivity right out of the box. >>
murphy55d
11,542
see below that
<< Parallel/USB connectivity.Cable not included. >>
Do I need just a regular USB to USB cable?
murphy55d
11,542
:confused:
It DOES come with a toner. Just not a cable. I've never had a USB printer, only serial. Do I need a USB to USB cable or what?
ScrapSilicon
13,625
either a Parallel or USB cable ....if you got a one or the other already use it for quick setup as you can find cheaper cables than what is sold at Staples...you should know to check HotDeals forum ...murphy....CompGeeks (if you making up an order...has USB cables sometimes for $4 6 foot)
ScrapSilicon
13,625
<< :confused:
just pointing out costs of use ...A-B cable
murphy55d
11,542
<< :confused:
Well for 70 bucks shipped, it's a pretty good deal. Has a rebate + staples coupon. 2,000 pages will last me a good long time. :)
Appreciate the help.
ScrapSilicon
13,625
reason 2 to point you towards the next cartridge is
<< Starter print cartridge >>
^--- usually a rather diminished use cartridge....B/W only no Color ...hope it suits your needs
