Level of importance for PC parts (Overclockers)
Hyperlite
5,664
yep, stock will do fine for pretty moderate overclocking (if your using an AMD anyway)
GuitarDaddy
11,465
1) CPU
2) Motherboard
3) PSU
4) Memory
Everything else doesn't matter
I agree that PSU is the most critical part of a PC system, but the question was which is the most important for overclocker. And if your CPU and or Motherboard don't overclock well PSU doesn't matter. You can overclock a good CPU on a bad PSU(you will be limited), but if you've got a bad CPU you can have the best PS in the world and it still won't overclock.
xsilver
470
1)mobo
getting a wrong mobo could mean zero overclocking -- eg. no bios features whatsoever
2)cpu
wrong cpu = very little headroom ---- high multiplier celerons, and maybe even the fx-55
3)psu
getting the worst psu doesn't guarantee you zero overclocking .... as long as the psu is working and can run stock
kensai - why is hdd (6)?? -- how does a better hdd help with overclocking?
n7
21,281
4
I would say it's a mistake to try to rate the importance of parts that are all important.
However, this list is the one i like if i had to rate them.
Originally posted by: Kensai
1: PSU
2: Mobo
3: RAM
4: CPU
5: VGA
6: HD
7: Case
8: Cooling system
Fern
26,907
174
Originally posted by: GuitarDaddy
1) CPU
2) Motherboard
3) PSU
4) Memory
:thumbsup:
But I'm starting to think memory is falling in importance with the advent of the 64 bit CPU's. They seem to OC fine with cheap ram/dividers.
Demon-Xanth
20,551
As far as the actual overclocking potential goes:
MB
CPU
Heatsink (varies by CPU and what comes with it)
Memory
Vidcard
Power supply
Hard drive
Optical drives
As far as what gives the best actual PERFORMANCE, that varies greatly by what you're doing. Often day to day stuff stresses the HD more than alot of other components, games at low res stress the CPU, high res stress the videocard...
theMan
4,386
this is the importance for overclocking, so you dont need a good cpu, because you're gonna oc it.
1. psu
2. mobo
3. cooling
4. cpu
5. memory
6. video card
7. all that other junk
Big Lar
6,330
It all matters/Period.
You need components that will work together and Not have software/Hardware conflicts.
Power Supplies have always been a Major issue, but not until of late has it come to the point where they have taken it seriously, I used to bark all the time about the PSU, but back then, noone listened. Next is the Mobo. It's where it all begins, if the board is a peice of crap, you are not going far with it.
Most Modern day Processors will overclock to some extent, some more than others.
Cooling.... well, I can't quite say enuff about that, so I will not, you get the hint.
MobiusPizza
2,001
CPU = Mobo = RAM = PSU
Any of that performs badly, you aren't going to be able to overclock at all even if other components are fine
Concillian
3,751
8
In terms of gaming performance:
1) Video card
2) Memory (size)
3) Mobo/CPU (together)
4) PSU
5) Memory (latency)
6) Memory (speed)
7) Hard Drive
50) Case
In terms of normal usage performance (browsing, email, Excel, minor multi-tasking, etc...)
1) Memory (size)
2) Memory (latency)
3) Hard Drive
4) Mobo/CPU (together)
5) Memory (speed)
6) PSU
7) Video Card
The Pentium Guy
4,327
1) Video card
2) Memory (size)
4) PSU
5) Memory (latency)
6) Memory (speed)
7) Hard Drive
50) Case
1) Memory (size)
2) Memory (latency)
3) Hard Drive
5) Memory (speed)
6) PSU
7) Video Card
Why the hell do you have PSU listed before teh video card.
Elcs
6,278
1) Video card
2) Memory (size)
4) PSU
5) Memory (latency)
6) Memory (speed)
7) Hard Drive
50) Case
1) Memory (size)
2) Memory (latency)
3) Hard Drive
5) Memory (speed)
6) PSU
7) Video Card
The OP never stated what part was being overclocked. Most people I assumed have assumed that the CPU is the piece of hardware being overclocked. Therefore the Graphics Card makes very little difference to the overclockability of the CPU therefore PSU is more important.
