stuckinasquare3
I not too long ago got a lanboy air (http://www.newegg.com/Product/Product.aspx?Item=N82E16811129093). The thing has a ton of air flow due to the open design and plethora of fans I've got in it. I originally bought it because I thought it would be cleaner and more fun to work inside but it's really not. I'm tired of fiddling around with multiple cables trying to plug in hard drives. The cable routing isn't that good.
Then I saw this case http://www.newegg.com/Product/Product.aspx?Item=N82E16811133192
The level 10 gt. At first glance it actually looks kind of ugly on the outside but there are a couple reasons why I'm thinking of buying it anyway.
1) hot swap bays for hard drives.
2) great cooling
3) plenty of cable routing
4) a cool feature that I really like is that all the fans are connected and the door fan uses a contact connection so you can easily take off the side
Does anyone own this case and have anything good/bad to say about it? Or can recommend a better/similar case
2) great cooling
