Letter H scrolling down the left side of the screen after POST
Milkman00
I have been doing computer stuff for a long time, and this is a first for me.
I have a Toshiba laptop. It goes through all of the BIOS tests and when it starts to boot off of the hard drive, it scrolls the letter H in the left column until the end of time.
I have tried to boot to a memtest CD, and a Ultimate Boot CD, but unfortuantely the memtest locks up within 2 seconds of starting to run, and UBCD doesn't make it much past the boot selection screen.
I found ONE instance of someone else having this problem on Google, and he said it was his CPU. I found that rather hard to believe, but at this point I really didn't know what else it could be. I replaced the CPU and the problem is still there. I would appreciate any other ideas. The only other thing I can think of is that:
  • The used CPU that I purchased has the same exact problem (unlikely)
  • System board needs to be replaced.
What do you guys think?
If memtest is locking up, are you sure it's not a RAM issue? Albeit an odd one. If it starts with the hard drive load, almost sounds more like a virus though.
If there is more than one memory stick you could try them one at a time, and exchange positions, to see if symptoms change. It would be nice (and lucky) to only need a memory stick.
Jim
I feel real stupid...
The problem was memory. It just didn't feel like a memory problem AT ALL. Did the stick elimination, and that was the problem.
VERY weird. Anyway thanks all for the help!
It looks like you did get lucky! When I remember, I usually start troubleshooting with a memory check because it uses so little other resources and gives me one good starting point. Good news.
Jim
