I got bored with my sandy and Im now trying to see how stable I can get it with the least amounts of volts.
Here is my first try with avx enabled and 8 threads of linp.
1.336 volts for 4,600mhz
thats the best my chip will do scaling wise as it take 1.376 to get it to 4,700 mhz stable for 5 passes with 8 threads running and then I need 1.425 for 4,800.
I can boot windows and do everything without any stability problems with way less volts but its not intel burn test stable for even 1 second.If you can get 5 passes with 8 threads and have sp1 windows 7 with avx enabled your system is pretty much rock solid for daily use.
