- Dec 9, 2000
- 16,528
- 4
- 0
Not all that familiar with the details of the physics of lightning and not all that experienced with applying all these equations and theories I've learned with the real world, but something that comes up all the time is why it's safe to be in a lightning storm. Some people say it's because of the rubber tires, other say the car is a Faraday cage and others cite the skin effect.
here's my take, many corrections will probably be needed:
1. Rubber tires
There is a potential difference between the cloud and ground and eventually the difference is so great that air breaks down and electrons are ripped away and charge is able to flow, ie current. Now, rubber is a terrific insulator, so the car is not grounded, for all intents and purposes it can be considered a floating point, right? the same potential difference that exists between the cloud and ground is not the same that exists between the car and cloud.
2. Faraday cage
Some sources I looked up say that a Faraday cage only works with static electricity and that lightning is certainly not static. Furthermore, most cars are not made out of metal (fiberglass, etc) so the Faraday cage argument wouldn't apply anyway. But if the car were made of metal completely, and a charge was placed on it, then surely the charge should remain outside...
3. Skin effect
The skin effect is only applicable to signals of some frequency (ie not DC). Knowing very little about lightning strikes, if I had to model it, I would most likely using an impulse and as such the delta function (don't you math people say anything about calling the dirac delta a function
). anyway, the impulse has a constant value at all frequencies if I remember correctly, but it's... weird to me because it doesn't really have a frequency. It's like, BAM! and it's over, although then I guess you would need to analyze the impulse response of the car (should have paid more attention in signals class).
Discuss.
1. Rubber tires
2. Faraday cage
3. Skin effect
Discuss.
