LenStar Web not closing out properly
Aquila76
3,549
www.facebook.com
I know you guys all work in different fields in tech, so here goes:
I currently work at a law firm and we have to use a Java-based Internet Explorer only application for tracking and updating the foreclosure process for our clients. It is called LenStar Web. On at least three PC's (mine included) when you close the LenStar IE window, the window disappears, but leaves the IEXPLORE.EXE task running in the background. I can tell when the task is stuck running because if you try to launch anything else (Office apps, IE, Firefox, whatever) the system just hangs until you End Process on IEXPLORE.EXE in task manager.
Is anyone else out there using LenStar and having this issue? All of our PC's are the same, HP SFF's with P4 3.0C's and 512MB RAM running WinXP SP1 and IE 6 w/all updates and the latest Sun Java (1.5.0_02-b09). Some of them have this problem, some don't. Even the ones with this problem do it randomly throughout the day.
I have a pretty good tech background, but I haven't dealt much with Java or Web-based apps to properly diagnose what's going on. My impression is that somehow Java is keeping IE from shutting down properly, but I don't know how to figure out where/when/why. Thanks for any help!
EDIT: Yes, I did contact LenStar's tech support, but they have not responded despite a month's worth of phone calls and e-mails. They remind me very much of the mortgage banks' 'Customer Help Lines' that do the same thing.
Codewiz
5,758
I would actually back the java version down to 1.4.xx
I know a project I work on has issues with something that was changed in 1.5.0
kamper
5,513
Any differences in the versions of IE, different windows service packs, etc?
Aquila76
3,549
www.facebook.com
No, they're all the same. The updates are distributed so all the PC's are on identical levels of software.
Aquila76
3,549
www.facebook.com
Thanks, I'll give that a try.
Edit: How would you change the rev? On my PC at home which had earlier versions of Java, I was able to do this through the Java Control Panel applet, but it appears that 1.5 was the base install on these boxes.
Aquila76
3,549
www.facebook.com
I tried installing an older version of Java and even using IE's not-quite-ready-for-primetime built-in Java and it still does the same thing. I'm just gonna say that this app is pretty broken, and wait for the next LenStar release (sometime in September) to hopefully fix it.
