Sorry if this is a dumb question, but is there a maximum "safe" length for a usb printer cable? Trying to hook up an HP 1320 laser printer, in case that makes a difference. Can I use a 15' cable and a 6' extension cable which are cheap from Acortech, or do I need to buy a more expensive 20' cable...if I do, can anyone recommend a good site? Does the quality of the cable matter for this?
I was concerned because I read somewhere (don't know if it is bogus though) that 5 meters (16') was max. for usb unless you got an extension with a booster.
Thanks for your help.
