legacy motherboard help
Tripleshot
7,218
I am looking for a link to a site that can help me find drivers for a legacy socket 7 motherboard I can only identify as VT-503 It has an intel chipset. I need PCI bus controllers for it. At every boot up,it says a "pci board not detected " In the control panel/system properties, other devices is yellow question mark and yellow pci bridge and yellow pci uneversal serial bus. Its running Win95B.
Is there somewhere I can find info on the mobo and download the needed drivers?
crypticlogin
4,047
From the looks of it, it may be a FIC VT-503 board but it seems standard enough that Win95 should be able to pick up the buses. Have you checked your BIOS settings? There are a few BIOS updates from FIC here. And the VT-503 manuals can be found online here.
Hope this helps you get started.
Tripleshot
7,218
Thank you. I will get to work and see if this helps. I'm sure your asssitance is valuable to fellow readers. ;)
