Left 4 Dead - X360 controller on PC?
sanzen07
402
Can you use the XBOX 360 controller in Left 4 Dead on the PC? Didn't see anything about it in the official system requirements.
Canai
8,016
Yes. Do you want to? No. :p
It works without any additional setup IIRC... I used mine for a few rounds but rage went-back-to-keyboard-and-mouse after that.
n7
21,281
4
Yes.
My roommate only plays PC games that he can use his controller with...so he got L4D for PC because you can do that.
I personally don't know why in the world anyone would prefer a controller over mouse/kb, but some people do, & some like my roomie do really well with the controller too.
Eeezee
9,922
You can, but WHY would you want to? PC gaming's greatest advantage is the use of a keyboard+mouse for FPS games, which improves control considerably.
Jules
LOL, He asked a simple question and all you get is some bullshit about KB+Mouse peeps.
Anyways, Yes it should work fine.
Koudelka
539
Haha. Well everyone has a point. I'm sure he gets his ass handed to him in L4D by any player with half a brain and then ridiculed when they find out he's on a 360 controller.
But hey, whatever he enjoys. To each his own.
skyofavalon
328
360 controller works great for this game.Only problem is when ever I switch back to Keyboard & mouse it changes the configuration back to default which got annoying.Fallout 3 is another game that works great with the 360 controller.
Industrial
249
You guys forgot to mention that he needed the wireless receiver if he's using wireless, it's about $15-20. One annoyance is, if the controller is registered to your xbox also, you have to turn your xbox off when you turn on your controller, but there's no problems with the controller being registered to both.
Also there's no way to turn off the controller, just let the controller turn off by itself. No big deal, turns off after 5-10 minutes.
You can also use the PS3 controller, but you have to use the usb dongle and some software. Get the software off the net.
L4D isn't that bad to use with controller, because you don't have to be so accurate since it's not a 1 shot your dead type FPS. If your accuracy is bad, you'll hit your teammates often, and they'll be pissed off at you!!!! If you have an xbox and and a gaming PC, get the PC version. Playing with the controller, you'd think you were on the xbox, but with better graphics and you can avoid most of the annoying kids on Xbox Live. Plus the mods and free DLC is a plus. And PC games are generally cheaper.
I prefer kb/m, but I'm pretty good with the controller also. I'll hook up the controller when I want to lay back and be in a more relaxed position and play. Use a mic, otherwise it kind of defeats the purpose of not using the kb. As far as accuracy, headshots, not hitting teammates...etc is concerned, I'm usually 1st or 2nd in the ending stats in the majority of the categories. Then I'll say it at the end that I was using the controller. Some people can't believe me, others will say it's not a big deal.
I'm better with kb/m, but it's more relaxing with the controller. If playing with the controller is better in both comfort and accuracy for you, then just do it. Who cares what people say.
ashishmishra
906
Good points Industrial, btw one of my friends has issues with his hands. It is physically very painful for him to use keyboard and mouse for long durations, needless to say he prefers gaming on the pc using the 360 controller.
OP: My friend says that the 360 controller is very well supported in L4D.
