My friend got LED lights as main headlights for his Scion tC.
Good thing about LED is that they're pure truest white, unlike yellowish bulbs. I guess it's a poor man's HID solution. They were pretty bright too, just as much as regular bulbs.
I'm wondering if there is one for my car Mazda 6? The bulb type is H1.
[edit]
While I'm at it: What are the pros and cons of LED vs bulbs?
Don't LEDs last forever? You never hear LEDs burning out, there's no 'coil' inside that lits up.
Don't they also produce more true colors?
What are the fundemental difference between the two in terms of technology?
[edit2] From wikipedia
Advantages of using LEDs
* LEDs are capable of emitting light of an intended color without the use of color filters that traditional lighting methods require.
* The shape of the LED package allows light to be focused. Incandescent and fluorescent sources often require an external reflector to collect light and direct it in a useable manner.
* LEDs are built inside solid cases that protect them, making them hard to break and extremely durable.
* LEDs have an extremely long life span: twice as long as the best fluorescent bulbs and twenty times longer than the best incandescent bulbs.
It seems LEDs are simply just superior than incandescent bulbs.
This means in the future, LED headlights will be better than HIDs? At a fraction of a cost? $20~ each vs $700 HID kit !
[edit]
