disappoint
- Dec 7, 2009
- 10,132
- 382
- 126
That sounds awesome, nice to know that there's a solution for this already. I'll definitely look into that when I do decide to do it.
Looks like the actual addressable LED units are buyable individually too. Imagine the possibilities if you do a matrix along the fascia. :biggrin: I'm guessing these have a unique address almost like a MAC address and work similar to "1 wire" sensors?
You don't want to buy them individually unless you're going to sew them onto fabric using conductive thread or something. Too much soldering on your part to use individual ones. Much easier to get the 5 meter roll with weatherproofing. They are all soldered on flexible PCB already. They come in black or white PCB. I chose white because they will be installed in a white window sill. You'll want black if they will be installed on something where the background is black or a dark color.
Even though they will be indoors, I got the ones with the weatherproof jacket to protect the LEDs and keep them clean (it's easier to clean the weatherproof jacket than LEDs on a PCB.) and in case I ever want to install them outside. A word of caution: Even though the PCB is flexible, it's a bit delicate in that if you flex it sharply too often it could break. Mine hasn't yet but that is because I was aware of this already and treated it carefully. If you have to make sharp bends you'll want to bend it once and leave it like that to avoid damage. Turns that are wide are not a problem but too many sharp bends in the same spot should be done as few times as possible. If you do happen to break it though worst case scenario you'll lose only 1 LED because you can cut the damaged part out and solder the rest of the strip together.
They don't have an address like a MAC address, they require specific timing to address them. But if you use for example an Arduino, thanks to the open source library available on Github, programming them becomes very easy. I got you covered on the code and any questions you might have on this just PM me.
