LED Light Bar Research - Microbeam?
Romoko
Dearest Anandtech,
So I've been tasked with finding the most consistent and precise lighting solution for my boss.
I am attempting to light small objects completely with little to no shadows and as little glare as possible for photography.
Currently I found a LED light bar made by a California company called Flolight. It would be a very viable solution for large areas, but I am also looking for smaller, articulating "gooseneck" lights.
What are your experiences with lighting, and what companies can you suggest for me to further research?
Anything helps!
This is a very broad and vague question. How big are your subjects? Are they stationary?
Either a lightbox or a pair of softboxes and a backdrop will be your best choice, depending on subject size.
Sorry for the vagueness. The subjects are all under 15cm and stationary.
My main goal is to find quality manufactures of LED light bars.
