Thinking of doing some work to a bar & cabinet I'm about to make for my place and was looking for some LED lighting solutions. More specifically I have no idea what I should get.....
Basically I'm looking for an RGB solution to display multiple colors solid-on or special effects controller with fade, strobe, different colors, chase etc.
I found something on E-bay which looks like what I want but I'm worried about the quality of the lighting. The controller appears to be able to do what I want but I want to be able to contol the timing so that either its short fast sequences or longer sequences.
Secondly I'd like to be able to control the intensity of the LED bulbs ( I dont know if this is possible with LEDs but it would be nice).
Thirdly I'm looking for a strip thats about 4-5 meters long and then splits off ie a Y pattern to two more LED strips off about 3 meters each. I'd also like a solution of 3-4 pieces of seperated 2 meter length pieces running in an 'extended Y' configuration
If anyone knows any stores that sells custom lengths or could tell me what I should look out for in terms of features of which LED bulbs & controllers I should look out for. I dont mind paying a bit more for the higher end quality parts I'm looking for a simplified solution. I was talking to an EE friend of mine and his soluion was to plug a PC into the controller board to control everything........
To give you an idea I'm looking to build something like this:
Pic 1
Pic 2
Pic 3
Pic 4
They have a controller on their website but it looks like that plugs into the serial port to get the desired effects. I'm guessing I can just preprogram it and let it be? Would it be hard to code for something like that (I'm clueless when it comes to this stuff). I'm really not to keen on plugging my laptop in every time I want the effect change I would rather pay for an external controller box.
This is also something else I like:
Pic 1
Pic 2
Pic 3
Pic 4
One thing I dont like is what looks like color bleed in the white shot though I'm guessing there isn't much I could do about it?
If anyone could help me out I'd really appreciate it
Pic 1
Pic 2
Pic 3
Pic 4
Pic 1
Pic 2
Pic 3
Pic 4
