LED cpu temp diodes
blakeatwork
4,113
Anyone know if there is a display that will show the temp externally, without running a seperate program?? Sorta like a meat sticker, except you would run the connection underneath the HS onto the die??. Might be a good idea..
WarCon
3,920
Yeah it is a good idea, but one thats already been done.
Compunurse and Digital Doc are models of what you are talking about. The digital doc 5, I believe has 8 temp probes and it monitors fans. All from a front panel display that fits in your 5 1/4" drive bays.
2Cooltek's shopping place under cases.
