I don't know if you can buy this as a separate unit. I removed the module(two screws) from an Antec Hard Drive Cooling System...CompUSA $30.
It's very small..1.5"x1.5"x 1.4" deep. It's powered by an included std molex connector. It has two temp probes, 150mm and 700mm. On the back side are two 3 pin fan connectors. The speed of both fans is controlled by the short probe. The cooler had two small fans, 40x25mm.
I'm not using it to control fans....I just wanted the LED Temp read-outs. I'm measuring case temp and CPU temps. It cycles between the two every 4 seconds. The indicator LED blinks if the temps go over 45c. You can also set it for F. There are many possible uses for this thing....That case in the pictures is my silent project. The LEDs give me an instant temp reading.....plus it looks stunning at night. Wish I could find more of these at a better price...
LED Mod
LED Mod
