led case fans
I have the Coolermaster fans and they do an excellent job. Lots of air noise but maybe that's the large grills on my case.
-Por
-Por
in a lian li pc65
should i get a mixture of blue and white or all blue or all white
there are two in the front of the case, so the color would show through the front air holes
and there is one on top
and there is one in back
there is a window on the left side
be my interior designer
fan noise is based mostly on rpm since basically all use sleeve bearings anwaysy. if one runs faster and louder,u can just use a fanspeed controller. course its better to start out at a lower rpm since lowering rpm will dim lights. and yes, fan grills do kinda make noise, i have that case and i sliced out all the 80mm fan grills. more light shines through to boot🙂
The best LED fans out there...without a question are the Vantec UV reactive ones...those look awesome and for the noise lvl/size they push a lot of air!
