- Jan 9, 2000
- 791
- 1
- 81
I have a 8 year old Dell desktop pc.
The problem I have is a quirky one that seem to point to the p/s.
The problem is during the bootup it stops mid point during the post. After trying to power on again, it still freezes. I I unlug the unit for a minute or so then plug back in, the unit (most times) will boot normally.
Finding a p/s is a problem. The p/s in the unit has a rear facing fan (fan exhausts the air in the back of the case. Every p/s I see has a top or bottom fan for cooling.
I'd like to go the local Best Buy and buy a p/s and just lay it on top of the case and use it to power the unit. If it works,,, it will be a temporary fix until I can find the right replacement p/s.
Will this work??? The current connectors are sata and the mb connector if I remember right is a 20 pin connector.
Again, just for trouble shooting and temp fix,,,, can I leave the p/s outside the case?
