Leadtek WinTV Tuner RM 2000 & Audigy 2 ZS Questions
galbicake
I just installed the Creative Audigy 2 ZS retail to go along with the Leadtek WinTV Tuner RM 2000 need help tweaking.
I was having problems getting any sound out but it is fine after I reinstalled the drivers for the TV Tuner.
Channels stop working after 79, the visual and sound gets fuzzy. I have Comcast cable with their Digital programming so I can get above Ch 100. The TV Tuner can go up to 125 but only in analog. So in theory, I should have channels 80-99 right?
There is this abrupt popping sound when changing channels. I tried all the options they offer for Audio Input and none of them seems to solve this. Is this sound card related or the TV Tuner?
Lastly, I have a microphone that does not seem to work anymore. Has anyone had any experience fixing this problem? I think it is because of the TV Tuner because it stopped working immediately after I used this card. The mic itself, has been tested on my other computer and it is fine.
Thanks,
I can't offer any advice on the Audigy problem, except to suggest that there may be a hardware conflict, and you should try updating the driver for both devices.
Also, unless that card has a QAM decoder you can't get digital cable channels. You're only getting the analog channels, which on my Comcast setup stops right around 75-79 too (there is a single shopping channel on 95).
Thanks,
I thought digital started at 100.
As for the hardware issue, I thought I updated with the most recent drivers...
Anyone else have an idea?
