Leadtek Winfast : VHS to DVD Conversion
austin316
I have my vcr hooked up through the yellow composite hookup. However, there is no where for me to input the white cable to get sound, how do I do this?
Also, I'm capturing at Mpeg-2, is this correct?
Thanks
Are you asking how to connect the sound output from your vcr to your video card? :Q
Geek Card Pls....
You should be connecting it to the line in on your sound card. Or worst case, the mic jack on your sound card...
-Jaison
edit: grammar
Geek Card Pls....
-Jaison
edit: grammar
I guess I need a converter then. the plug I have is too big.
Even my capture card came with an adapter for the sound card. Left/Right channels (red/white) into 1 plug.
Originally posted by: Goosemaster
1. you need a mini-jack to RCa adapter.
2. Yes, capture in mpeg2 if you machine is decently fast.
I got a 1600+ XP in once pc, is that fast enough?
Or should I hook up the capture card to my Athlon 64 3000+?
I've never been very happy w/ the capture from VIVO cards. The audio seems to be slightly out of sync. Best of luck. 🙂
