Leadtek WinFast TV2000 XP - What tuner?
MrTux
717
I downloaded dscaler to try it on with my card, and it asks what specific tuner your card has. It didn't autodetect it. Does anyone know what tuner these cards use? Thanks.
DanTMWTMP
15,908
19
there's a number on the silver block on ur TV tuner...
there's like one or two manufactuers that make tv tuners for various companies....
i also have a winfast...i was able to find software and drivers by just doing a google search on that numbers/letters on the silver block of the TV tuner...
the number also should be present on the box of the card...if OEM...sux0rs!!!
Goi
6,772
7
Peel off the sticker on the tuner, it should be underneath. FWIW, my PAL version of the Leadtek TV2000XP apparently uses a Philips tuner. At least, Dscaler works with that setting, try that first if you don't wanna peel the sticker. Of course, choose NTSC if you're in USA.
