I've been trying to get this thing to work but the new version or PVR freezes on the splash screen and now I can't uninstall it. I can't get Dscaler to work either. I'm using WinXp
I'm using the latest drivers and PVR software and I've no problems like that. I wonder why you can't uninstall the drivers and PVR software? Did you try to do so in safe mode yet? If not, give that a try.
